I'm struggling for a few hours already and can not find solution.
I have a sequence of png files with alpha. When I open single file in Xnview and convert it to truecolors from main menu the picture is changed according alpha channel.
When I use Sequence convert and add Convert to True colors in Transformation than press Go button, sequence is converted as expected. But when I export the script and run it from command line, resulting jpg sequence looks completely different. It is not converted to truecolors, alpha channel is just not saved (obviously with jpg)
-truecolor is not working for me from command line.
resulting script exported from xnview is simple as this:
nconvert -npcd 2 -size 256x256+0 -ctype grey -corder inter -out jpeg -n 1 24 1 -o dir\01.05_honda_CRX####.jpg -truecolors dir\01.05_honda_CRX####.png
I just do not understand . . .
thank you for your help
nconvert -truecolors
Re: nconvert -truecolors
right, the function in NConvert is not the same as XnView, i'll fix it
_murphy_
thank you Pierre!
Is there any timeframe for next release?
with regards
murphy
with regards
murphy
i hope to release new version in 1 month...
