XnView can't open TIFF-F files
aev
Post by aev »
XnViev 1.98.5 can't open a file format TIFF-F.
More information about the format: http://www.faximum.com/manual.d/client. ... ef.57.html
File Example: http://rghost.ru/32629081
I would be glad if you add support for TIFF-F.
Error message: "Can't read file". Thumbnails is visible.
Re: XnView can't open TIFF-F files
There is a read error, you can activate option/Read-write>Ignore error
aev
Post by aev »
Thanks. It works.
