Combine batch processing and rename
larsen
Post by larsen »
I know that I can rename multiple files at once and that is very handy, but is there a way to rename files with "Batch Processing"? I would like to resize images while at the same time renaming them to hold the creation date from EXIF data in the filename.
I found another thread (http://newsgroup.xnview.com/viewtopic.p ... 54&p=90452) where it is said to use XnConvert, but I´d rather not install yet another program and have to switch between XnView and XnConvert. Also, both functions are already present in XnView so why not combine them?
Lars
