Hello.
When printing Multipage TIFF files I have found out that "insert all pages/images of multipage source images) does it wrong. It's better to use pages <> to <> instead (from first to last).
Number of copies doesn't seem to work either, at least using FreePDF as printer.
Can anyone confirm?
[1.98.5 Win] More MP TIFF printing bugs
eL_PuSHeR
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
Re: [1.98.5 Win] More MP TIFF printing bugs
What's happened?eL_PuSHeR wrote:When printing Multipage TIFF files I have found out that "insert all pages/images of multipage source images) does it wrong. It's better to use pages <> to <> instead (from first to last).
eL_PuSHeR
It gets wrong numbering.
Instead of 1,2,3....end I get 1,1,2,3 or something like that. Very strange.
If I specify from first page number to last, page range (all) is okay.
I am not in browser mode, by the way. I have browser disabled at startup.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
could you send me a TIFF sample? and which print settings do you use?
eL_PuSHeR
Here you go. File is about 30KB in size.
http://www.mediafire.com/?q2f2vpp1a52fvzv
Options are set almost at default. For layout "single - best fit to page"
You don't even need to print. The print preview is already wrong.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
eL_PuSHeR
Is this the same bug, by the way?
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
Ok, i have the problem with 'all pages'
eL_PuSHeR
Merci Pierre.
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
