0.39 win-x86: Stop animation shortcut override
budz45
Post by budz45 »
Hello there,
As mentioned by marsh in another topic: http://newsgroup.xnview.com/viewtopic.p ... 241#p95624
the ESC key is supposed to be legacy XnView win behaviour to Stop the playback of an animated file. ok.
But when I go into XnView MP's 'Shortcuts' editor in the settings and then I assign my own Shortcut/Hotkey to the "Start/stop animation" command (the shortcut I personally use here is 'Ctrl+Space') then the behaviour of the ESC key still remains.
Could this small issue be fixed for the following things:
1.) So by default in the shortcuts editor 'ESC' is displayed as default command (displayed buy greyed out)
2.) When I change this command to any shortcut of my choice - after doing this the ESC get's fully overridden meaning so that ESC is not on this anymore.
thank you.
budz45
Re: 0.39 win-x86: Stop animation shortcut override
Post by budz45 »
Hmm.. but ESC key also is a shortcut for closing a tab (viewer) too.
So what is the best solution?
Yes, ESC is always used to stop animation, you can't override it
