Question creating PDF file with Deflate compr.
eL_PuSHeR
Post by eL_PuSHeR »
Hello.
Why when you create a multipage PDF file using Deflate (ZIP) compression (lossless) a tick box appears below saying "quality 80%"? Just curious. Lossy compression is always 100% quality, isn't it? Am I missing something?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Re: Question creating PDF file with Deflate compr.
right, quality is only for jpeg
eL_PuSHeR
Post by eL_PuSHeR »
Thanks for the explanation.
Intel i7 5960X
8 GB DDR4 (2100)
