Use system's Qt on Linux?
anonymous_user
Post by anonymous_user »
I apologize if this was asked or explained before, but why does XnViewMP (for Linux) include its own Qt libraries rather than use the systems'? I mean it makes the download fairly large and I prefer the way my system's Qt is themed.
Re: Use system's Qt on Linux?
I use modified Qt version, so it's not possible to use system Qt libraries
anonymous_user
And why do you need to use a modified Qt?
anonymous_user wrote:And why do you need to use a modified Qt?
To fix some problems, and add some features...
