Problem with "browse with xnview"
munin
Post by munin »
If i click to browse with xnview in a folder, i get a warning screen saying the file doesnt have an associated program...
And when i try to disable the option Add "browse with xnview" in tools, it just doesnt. Whenever i enter the options again its reenabled.
I tried disabling it with admin rights but its the same thing.
Is tehre another way to remove the context menu entry?
My windows is 64 bits if that helps.
Re: Problem with "browse with xnview"
Do you execute XnView with admin rights (context menu on icon)?
triff
Post by triff »
Argh, that just had me too. Silly Windows 7... Sorted now, cheers!
