Disable update checks?
nameless
Is there any way to prevent XnView from checking for updates at startup? I've checked settings, FAQ, registry, I Googled... Can't find a way.
- Forum Librarian
Re: Disable update checks?
You can set it to Monthly/Weekly/Daily/Never in Tools » Options... » System integration » Integration » Check update.
nameless
Thank you. I really did look, but somehow missed it. I'm sorry.
- Forum Librarian
No problem
