Thumbnails build/rebuild doesn’t work (properly)
mckenzina
Post by mckenzina »
After rotating a photo and recreating thumbnail it gets smaller. And it happens every time I recreate thumbnail after rotating this photo again. I tried to remove it using metadata clearing and then recreating from Edit / Metadata / Recreate EXIF thumbnail – but nothing happens.
I googled a bit and found this: http://superuser.com/questions/220074/g ... l-for-jpeg, and then tried also with nconvert. But nothing happens as well (I suppose same method is invoked).
It would be great if rebuilding didn’t shrunk thumb. And it would be great if (re)building would work ;) How about defining a default size of thumbnail in settings?
Re: Thumbnails build/rebuild doesn’t work (properly)
Could you send me the original file and the modified one?
mckenzina
Post by mckenzina »
xnview wrote:Could you send me the original file and the modified one?
Shore, I've sent you via PM
ok, i can reproduce...
