Scanning "film negative" and convert to "positive"?
Peter2
Post by Peter2 »
I would like to know if it makes sense and creates a medium quality to
- scan my negative-stripes from my 35 mm camera and
- convert it with command "Negative" to a "coloured photo".
Crazy idea?
Peter
Re: Scanning "film negative" and convert to "positive"?
Peter2
Post by Peter2 »
Thanks, XnTriq
XnTriq wrote:
Now I learned (again), that the search in the forum does not use wildcards automatically: "negativ" is not "negativ*" :|
XnTriq wrote:[/list]
ooh, huge program. Could be that it takes more then 5 min to understand ...
Regards
Peter
Peter2 wrote:Now I learned (again), that the search in the forum does not use wildcards automatically: "negativ" is not "negativ*" :|
Out of frustration with phpBB I created an OpenSearch plugin for web browsers.
Peter2 wrote:ooh, huge program. Could be that it takes more then 5 min to understand ...
There's a learning curve, but you won't regret spending some time with JPG-Illuminator.
