Nconvert can't read the picture
nh2user
Post by nh2user »
I am trying a batch file :
nconvert -keepcspace -keepfiledate -opthuff -keep_icc -D -q 95 -subsampling 2 -smoothingf 0 -dct 2 -out jpeg -i -l filelist.txt
here is the code.
Any comments on the code is appreciated.
The error I get is : can't read the picture. it's a .jp2 picture that xnconvert 1.1 converts fine and xnview open fine
any tips ?
Re: Nconvert can't read the picture
Do you have the Xjp2 plugin?
nh2user
Post by nh2user »
Hummm.... No. What to do ?
nh2user
Post by nh2user »
xnview wrote:Do you have the Xjp2 plugin?
Ok, I put all plugins in the Plugins Directory.
now it tells me that the program can't start because msvc71.dll or something is missing. Two dll's missing.
I don't understand, isn't the program a command line ?
what now ?
Peter2
Post by Peter2 »
nh2user wrote:....now it tells me that the program can't start because msvc71.dll or something is missing. Two dll's missing.
http://answers.microsoft.com/en-us/wind ... 0d3683bc89
Microsoft wrote:Msvcp71.dll is a Microsoft C Runtime library and it is required to run several Microsoft and non-Microsoft applications on a Windows system.
Maybe your PC is not up-to-date relating to the "C runtimes"?
Peter
nh2user
Post by nh2user »
Peter
I just downloaded the two files missing :
MSVCP71
msvcr71
and put them in the same directory as nconvert. You should put them in the original release. Not everything has these files.
Peter2
Post by Peter2 »
nh2user wrote:...I just downloaded the two files missing :...
So your problem is solved?
nh2user wrote:...You should put them in the original release. Not everything has these files.
These runtimes from Microsoft (in different version: 2007, 2010, ...) are essential and necessary for many, many applications. The best way for the user is to download the entire packages from Microsoft and the install them correctly.
Peter
nh2user
Post by nh2user »
Peter
Putting them with the release makes sure your release is portable. and idiot proof for the ones like me.
Just a suggestion.
nh2user
Post by nh2user »
What do you think of the command line ?
is it good / ok ?
Peter2
Post by Peter2 »
nh2user wrote:What do you think of the command line ?
is it good / ok ?
If you ask me - then I'm sorry to say that I have no experience with command line. I hope another user will reply.
Peter
is it good / ok ?
Yes, the command line is good, are you able to load jp2000 files?
nh2user
Post by nh2user »
is it good / ok ?
Yes, All is good now !
