0.39 win-x86: Photo DISTORTION under MP's sized-window
budz45
Post by budz45 »
I cannot explain the technical term for this 'indexed' color distortion but I have indeed noticed this same distortion before with other super high-resolution images, particular with high-res images that have been sourced from a scanner.
Right, so the photo preview display's with the evident distortion in both XnView MP and XYplorer's 'preview' as seen here:
Image Image Image
Ahhh :P :?: But I cannot see any of the same distortion whatsoever when I view with Windows 7's native image viewer:
Image Image
So issue must be explainable to the least if not fixable immediately...Or perhaps there is a setting in XnView MP that I have overlooked no/yes?
Here is the same Hi-res photo image seen above in the screenshots for anyone to test
(5.7 MB):
http://www.megaupload.com/?d=KUWEHCR0
Or
http://www.sendspace.com/file/a9frq3
Thank you for reading. :o
XnView MP 0.39 | windows 7 sp1 x86 | program settings = xnview.ini
Re: 0.39 win-x86: Photo DISTORTION under MP's sized-window
What you see are Moiré pattern artifacts. The picture was obviously scanned from a print magazine without activated descreen filter.
Setting High zoom quality in Tools » Settings... » View to Reduce & Enlarge should smooth things out.
budz45
Post by budz45 »
Thank you Xntriq for this information.
Yes I have noticed this with many of my scanned magazines/newpapers but have never heard of this "Descreen" information to look out for.
So this topic is not a bug and should to another sub-forum... :wink:
