Loosing quality picture using gflax rotate function
FredG
Post by FredG »
Hello and thanks for all
I use rotate with gflax.It works fine but my dpi goes from 180 to 68 dpi. Is there anyway to keep good quality picture?
here the code:
temp= dir &"/photos/"& right(session("tab("&i&")"),len(session("tab("&i&")"))-InstrRev(session("tab("&i&")") ,"/") )
Myobj1.SaveJPEGQuality = 100
Myobj1.Rotate angle
Myobj1.SaveFormat = 1
Myobj1.SaveJPEGProgressive = True
Myobj1.SaveBitMap temp
set Myobj1=nothing
Thanks
Re: Loosing quality picture using gflax rotate function
FredG wrote:Hello and thanks for all
here the code:
Myobj1.Rotate angle
set Myobj1=nothing
Thanks
Yes, Rotate is not lossless function
toby
Post by toby »
Hello
When I rotate a picture, I get quite a heavy distortion. The
pic is not rectangular anymore. Max distorsion is at 45 degrees.
Has this bug been fixed in 2.40 ? I am currently using 2.27.
Thanks for any help !
Toby
toby wrote:Hello
No, i'll change soon the rotate function.
Toby
Post by Toby »
Hi Pierre
Ok, thanks. By the way: I like GflAx a lot, it's a great piece of software !
