When I go to resize an image, from the "standard size" dropdown list, there are more than a dozen settings that are neither "standard" nor "useful" in my opinion. I *frequently* resize images to 1920x1080 or 1280x720, neither if which appear in the list.
Can someone tell me where the list is stored so I can delete everything that's in there and add my own "standard" presets?
Thanks
The REAL Joe
Where are the resize presets stored?
- Forum Librarian
Re: Where are the resize presets stored?
In XnView v1.98.5, the presets are hard-coded (in the program's executable file).
XnViewMP v0.39 lets users add new presets, but you can't delete the default ones.
A workaround would be to create an XnView batch processing script (.XBS) for each size.
therealjoeblow
XnTriq wrote:In XnView v1.98.5, the presets are hard-coded (in the program's executable file).
Thanks - I'll give MP a try...
The REAL Joe
