A zip archive inside a zip archive is given the notepad icon and right click -> Open gives the message "Format of the file <*.zip> could not be determined".
Help please!
This could probably be fixed if full archive stream reading support similar to a zlib stream reader is implemented rather than extracting files in the archive to the file system.
Thanks!
Can't open archive inside archive
xv500
Re: Can't open archive inside archive
yes, currently archive in archive can't be browsed
