Not sure if this is a bug, a possible enhancement or a lack of understanding:
I wanted to remove a bracketed number from a group of filesnames e.g.
In Batch Rename, I tried:
Replace: K5__#### (#####)
With: K5__####
and
Replace: K5__#### (#####).JPG
With: K5__####.JPG
and
Replace: (#####)
With: [field left blank]
How do I do this?
Dan
Batch rename problem - 1.98.5
Re: Batch rename problem - 1.98.5
I suppose that you need Wildcards and RegEx (regular expressions) http://www.google.com/search?sitesearch ... 20&bih=923 for this job - and I believe that XnView has some limits.
Maybe take a look here: Recommended File-Rename-Tools?
http://newsgroup.xnview.com/viewtopic.php?f=38&t=17400
Peter
Peter
