Hello.
Is it possible to store the file name for multiple images in IPTC? In the Caption field.
Batch mode? Does it work with XnView or XnViewMP?
Thank you.
filename in IPTC
Re: filename in IPTC
You can do that with 'edit iptc' of XnViewMP
OOmatrixOO
Thank you for your answer.
I have also been found, but you have to edit each photo individually. It is then difficult for many photos.
I'm doing it now with a batch file and exiftool. Would be cool if you could somehow integrate it as an external program.
Greetings.
Greetings.
Silversleeves
I second the suggestion to bring Exiftool into the Windows native version. I even started a thread on it.OOmatrixOO wrote:Thank you for your answer.
Greetings.
BZT
