Any help would be be HUGELY appreciated.
Pantone colors displayed incorrectly
Kore
I'm new to XnView, so I might be missing something, but when I view (or export) Pantone colors they're wrong. The attached image shows the problem. It's the same file, viewed in Illustrator and XnView (the Illustrator file is correct). It doesn't seem to matter what kind of file it is (eps, pdf, jpg, ia).
- Forum Librarian
Re: Pantone colors displayed incorrectly
Have you configured the settings in Tools » Options... » General » ICC?
Kore
Thanks for the response.
I hadn't configured the ICC settings, but once I did, it didn't change anything. I pointed the ICC profile to the custom Spyder profile I have, and tried all the Rendering Intent settings, but no luck. Any other ideas?
- Forum Librarian
Unfortunately I don't have a calibrated monitor, so I can't do tests myself
- Bad colors in CMYK file
- Monitor profiles in XnView
- Monitor profile ICC file extension
- ICC profile handling
- Please help me with color management in XnView.
- Help regarding ICC profile settings
- CMYK colors are shown wrong
- Default colour profile
- How to use icc/icm screen profile ?
- Comment utiliser un profil icc/icm ?
- [BUG]profil icc utilisé comme destination
- CMYK support?
- 1.93.6B1 Colour management
- Use monitor profile file
- A: ICC-profile problem?
obelisk
ICC doesn't quite always work.
I've gotten XnV to agree with PS on one screen, but it's hit and run on others.
I use a Huey, and noticed that it generated an icc for one mon and not another (via hdmi)
you can send me the file?
Kore
@xnview - What's the best way to send you a file?
contact at xnview dot com
