Some more feedback
soulky
Some more feedback
Post by soulky »
1. When adding a new application to the context menu to be able to start it with ALT + 1 etc, it is not immediately possible to start with the keyboard shortcut it after it has been added.
You have to select it through the "Start with" dialaog 1 time only after that it is possible to start it with the keyboard shortcut.
2. Once a category has been assigned to a file, there is no way to remove the category again.
3. There is no way to assign own categories to tag them with own names.
4. It would be great to have the category names/tags as small icons in the thumbnailing view.
5. It would be great to have own names for the colour tags as well.
6. Also it would be great to be able to assign own keyboard shortcuts for rating, category/tags and colour tags
Re: Some more feedback
soulky wrote:1. When adding a new application to the context menu to be able to start it with ALT + 1 etc, it is not immediately possible to start with the keyboard shortcut it after it has been added.
Ok
In the categories panel (near preview) you can remove categories
You can create your own categories...
category name on thumbnail????
You can change them in xnview.ini
yes currently no shortcut...
