"Clean metadata" adds metadata
Peter2
Post by Peter2 »
I have TIF with EXIF, and tried to clean the metadata:
  <?xml version="1.0" encoding="UTF-8" ?>
- <XnView_script version="1.0" name="exif_del">
  <Clean_metadata flags="2" />
- <Output folder="D:/1234" filename="" case="0" format="TIFF">
  <Options overwrite="0" orgDate="false" keepMeta="false" keepICC="false" keepFolder="false" delOrg="false" multipage="false" allPages="true" openExplorer="false" />
  <TIFF compress="2" compressBW="6" oneStrip="false" />
  </Output>
  </XnView_script>
This works semi-fine, because the original EXIFs are removed and "Software: LIBFORMAT ..." is added.
How to remove it all?
Peter
Re: "Clean metadata" adds metadata
The software is not really a EXIF information, stored in TIFF header not EXIF header...
Peter2
Post by Peter2 »
xnview wrote:...stored in TIFF header not EXIF header...
But the "Properties" in XnView displays it in the EXIF-Tab.
Correct?
Peter
Correct?
Yes, to be able to save as EXIF in jpeg file...
