I think I've tried to look everywhere, but in the view menu is a sub-menu "filter by" which provides various option radio buttons, including "custom". But I can't find any way to create a custom filter. Can this be done? I'm interested in filtering using a filename mask.
scott s.
view -- filter by custom?
Re: view -- filter by custom?
option>File list
scott967
Thanks. I see in the file list there are 2 options for "custom" file types, set by extension. I will experiment with this setting and the view -- filter by and get an understanding of how these work together.
scott s.
scott s.
