Layers & PSP files
UndergrndMe
Layers & PSP files
Post by UndergrndMe »
I'm new to .psp files. XnView opens the file, displays an image which I can then convert. However, the file should contain multiple images but only one image shows up w/XnView. I'm guessing the different images are "layers," similar to psd files; if so, how do I "open" or access the other layers?
I queried psp, how to open layers, etc. & got no hits via forums. I hope someone knows how to go about this. :)
Peter2
Re: Layers & PSP files
Post by Peter2 »
Have you tried google-search:
http://www.google.com/search?sitesearch ... =psp+layer
Peter
UndergrndMe
I did a google search (duhhh!...thanks for the suggestion btw), and came up with many threads that all pretty much seemed to say the same thing: basically XnView does not currently support the layers in a psp file; only the bottom layer is viewable/convertible. According to XnView's author, Pierre, as of June 02, 2008, XnView does "not yet" support the layers.
Does this mean it might in the future? Corel files seem to be a dying breed.
Peter2
Post by Peter2 »
UndergrndMe wrote:...Does this mean it might in the future? ....
I don't now something about PSP and that stuff, but "the future" of XnView is XnViewMP
http://newsgroup.xnview.com/viewtopic.php?f=60&t=24056
Have you tired this?
Peter
yes right, i have not worked on layer for psp...
Drahken
Post by Drahken »
Xnview doesn't support layers in any format, although it does support superficially similar things like multipage tiff/pdf/etc, and multiframe/animated pics (viewing of, but not saving of).
The question is; Are layers and multipages similar enough that the current multipage functions could be adapted somehow, to make them work with layers?
yes multipage is used for psd for example...
