Currently, on the 'Actions' tab, the heading of the action parameters is irritating:
As you can see in the screenshot above, the heading of the action parameters (here: 'Blur') is highlighted in a way that one might think that it is selected (which is not the case, as far as I can see there is no such thing like a selection here). I'd appreciate if the heading would be highlighted in a different way. Or why not use a group panel with the heading "Action 'Blur' - Parameters"?
Below please find a draft which...
...uses a group box for the action parameters.
...uses different labels for the tab and the group boxes.
...which has a better window title (version number and 'windows' are both superfluous, if needed, the user can see the version number in tab 'About')
UI: Tab 'Action - irritating heading and some minor stuff
budz45
Re: UI: Tab 'Action - irritating heading and some minor stuf
It's not that irritating
But yes I can see your point about it looking less stylish.
Personally i think this should remain (for now) and not replace it with a 'circle-ui' as you have done in your second screenshot.
I may think of an alternative heading style later and post.
I've already changed heading with group box in development version...
