Width and Height parameters for YUV and RAW data formats
xiaoben
Post by xiaoben »
Can someone let me know how to change the width and height parameters when opening a YUV or RAW video/image file?
This feature is supported in XnView 1.98.2 for Windows.
In XnViewMP, the default format is SD (i.e. 720x576) for any YUV and RAW files, and the "Opions" feature in XnView for Windows seems not supported. Is it true? If not, what do I miss? If so, can someone fix it? Otherwise, this software would not be able to handle any format that doesn't have width/height information in it.
Thanks
Re: Width and Height parameters for YUV and RAW data formats
i must add it
xiaoben
Post by xiaoben »
Thanks.
