IPTC in TIF
Peter2
IPTC in TIF
Post by Peter2 »
I'm trying again some features of IPTC, here some remarks:
"Imagetype" (allowed only 2 bytes):
I set this tag with exiv/2 to "imagety", here my results:
Exiftool:
Imagetype                          : imagety
XnView-Export:
????                          : imagety
Same behaviour with "Subject" (allowed 236 bytes):
I set this tag with exiv/2 to "subj", IPTC-export shows:
Exiftool:
Subject Reference                          : subj
XnView-Export:
????                          : subj
Both tags are not displayed in IPTC-Dialogue.
Regards
Peter
Re: IPTC in TIF
Could you send me the file?
Peter2
Re: IPTC in TIF
Post by Peter2 »
xnview wrote:Could you send me the file?
Done.
Peter
Re: IPTC in TIF
Ok, no supported tag can not be showed or edited... XnView support only the most used iptc tag
Peter2
Re: IPTC in TIF
Post by Peter2 »
Another problem: I filled some tags with Exiv2.exe with German Umlaute - I entered
-- a ä o ö u ü A Ä O Ö U Ü --
XnView does not handle it always correct. Here is the result of the IPTC-export:
(Sorry - the forum does not except some special strings from the export-file. I have to replace them with XXX)
D:\IPTC_Test_Umlaute.tif
????                          : -- a ä o ö u ü A Ä O Ö U Ü --
Date Created                  : 65530000
Sublocation                   : -- a ä o ö u ü A Ä O Ö U Ü --
Country                       : -- a ä o ö u ü A Ä O Ö U Ü --
Original Transmission Reference: -- a ä o ö u ü A Ä O Ö U Ü --
Headline                      : -- a ä o ö u ü A Ä O Ö U Ü --
Source                        : -- a ä o ö u ü A Ä O Ö U Ü --
CopyrightNotice               : -- a ä o ÃXXX u ü A Ä O Ö U Ü --
Contacts                      : -- a ä o ö u ü A Ä O Ö U Ü --
Caption                       : -- a ä o ö u ü A Ä O Ö U Ü --
I will sent you the TIF with e-mail.
BTW: Also Exiftool handles both entries in a different way then the other entreis ... ???
Peter
Re: IPTC in TIF
It seems that these 2 fields are not encoded correctly... (in utf8, other fields are in local charset)
Peter2
Re: IPTC in TIF
Post by Peter2 »
xnview wrote:It seems that these 2 fields are not encoded correctly... (in utf8, other fields are in local charset)
Thank you Pierre. Yes, I found the problem in the definition of encoding - wrong entries had definitions "ft_stringw" instead of "ft_string".
Regards
Peter
Peter2
Re: IPTC in TIF
Post by Peter2 »
Peter2 wrote:... I found the problem in the definition of encoding - wrong entries had definitions "ft_stringw" instead of "ft_string".....
Discussing this issue on the TC-forum it is said that the problem is caused by XnView, not by TC-plugin:
http://ghisler.ch/board/viewtopic.php?t ... &start=116
Maybe you can take a look at this?
Peter
Re: IPTC in TIF
Strange, default encoding is Latin1, so fields must not use utf8. I've tested in photoshop and in zoner photo studio, and it's the same as XnView...
Re: IPTC in TIF
Please check XnViewMP 0.48
Peter2
Re: IPTC in TIF
Post by Peter2 »
xnview wrote:Please check XnViewMP 0.48
I took a file and set many entries to
The result seem to be OK.
IPTC-Export from XNViewMP: Not possible
IPTC-Display in XNViewMP: OK
IPTC-Display in XNView 1.98.4: OK
IPTC-Export from Exiftool: OK (wrong codes, but all the same..)
IPTC-Export from in XNView 1.98.4:
Object Name                   : -- a ä o ö u ü A Ä O Ö U Ü --
Edit Status                   : -- a ä o ö u ü A Ä O Ö U Ü --
JobId                         : -- a ä o ö u ü A Ä O Ö U Ü --
Special Instructions          : -- a ä o ö u ü A Ä O Ö U Ü --
Program                       : -- a ä o ö u ü A Ä O Ö U Ü --
Program version               : -- a ä o ö u ü A Ä O Ö U Ü --
Byline                        : -- a ä o ö u ü A Ä O Ö U Ü --
Byline Title                  : -- a ä o ö u ü A Ä O Ö U Ü --
City                          : -- a ä o ö u ü A Ä O Ö U Ü --
State                         : -- a ä o ö u ü A Ä O Ö U Ü --
Credits                       : -- a ä o ö u ü A Ä O Ö U Ü --
CopyrightNotice               : -- a ä o ö u ü A Ä O Ö U Ü --
Caption Writer                : -- a ä o ö u ü A Ä O Ö U Ü --
One small issue: The export in 1.98 has the colons ":" not exactly one under another ...
Thanks
Peter
