incompatibility between -xall and % in -o
mprost
Post by mprost »
Hi.
I'm having an issue trying to convert some TIFF files into PNG using NConvert 6.01 and Windows 7 Ultimate x64. If I run (from the command prompt):
nconvert.exe -out png -o %.png 11193.tif
I obtain "11193.png" (as expected), but if I run:
nconvert.exe -xall -out png -o %.png 11193.tif
I obtain ".png". The source TIFF file is not even a multipage one (trying with multipage ones yields the same result).
Am I doing something wrong? BTW, I think similar issues have been reported previously (here and here) to no avail.
Thanks.
Cheers,
mprost
keywords: specify source filename percent sign output filename
mprost
Re: incompatibility between -xall and % in -o
Post by mprost »
nobody?
ok, a bug, i'll fix it
mprost
Post by mprost »
Thank you very much.
Cheers,
mprost
mprost
Post by mprost »
xnview wrote:ok, a bug, i'll fix it
Have just tried with version 6.05 and it works perfectly, thank you very much.
Cheers,
mprost
bar_foo
Post by bar_foo »
mprost wrote: Have just tried with version 6.05 and it works perfectly, thank you very much.
That's strange: I'm having the same problem and it isn't fixed in 6.05 (64-bit), for me, when I try to convert one multipage file to another. For example,
nconvert -xall -multi -out tiff -o % *.pdf
only uses the filename of the first PDF file. It creates a TIFF with the name of the first PDF file, then appends the data from the first, second, third, etc. files. Or am I misunderstanding the syntax (my goal was to convert all the PDFs in the folder to TIFFs).
