[FIXED_RC7]RC6: F11 Crashes Program.
Start in browser mode. Press F11, program exits/crashes.
Not normal to do, but…
- Right, confirmed; that occurs only when not any pic is displayed as Preview, or when pressing F11 while nothing at all is selected / displayed.
- Of course, it isn't normal to press F11 in such cases, but a mishandling is pretty possible, and these errors might be planned : nothing might happen, IMHO.
Lesmo16,
This is hardly a life threatening bug, how many people will fire up XnView and press F11 without first having a file selected?
At this stage, it should be postphoned until a later version.
It's not just at startup, also after moving to an other folder.
EDIT: Pierre, would a possible solution be that pressing F11, when no thumb is having focus, results in highlighting the first thumbnail and then opening it in quick-fullscreen?
That's your opinion, OK. But why?ckit wrote:At this stage, it should be postphoned until a later version.
You've stated your opinion in several other threads.
I don't know about your special motivation, but it seems that Pierre luckily hasn't the same problems.
Everyone who believes in telekinesis, raise my hand!
Because no-one in his right mind would enter fullscreen when nothing is highlightedLesmo16 wrote:That's your opinion, OK. But why?ckit wrote:At this stage, it should be postphoned until a later version.
I agree that crashes are bad though, you loose all your tabs, all modifications that weren't saved etc.
Support!Olive wrote:EDIT: Pierre, would a possible solution be that pressing F11, when no thumb is having focus, results in highlighting the first thumbnail and then opening it in quick-fullscreen?
BTW: Look at this thread. Not exactly the same, but nearly ...
With set focus to one thumbnail the F11 error won't occur - so why shouldn't it be the first?Hacker wrote:BTW: I disagree with opening the first file upon F11 automatically.
My suggestion about showing preview of first thumbnail from this thread should be optional - like I've posted.
Re: RC6: F11 Crashes Program.
This has been fixed in RC7.marsh wrote:Start in browser mode. Press F11, program exits/crashes.
