Bug when saving modified Multi-Frame TIFF
CH-Systems
Post by CH-Systems »
Hello!
When a multi-frame TIF is edited (e.g. rotation of frame 2 by 90°) and then saved, XnView opens a message box and asks if I want to save all frames with the choices OK and Abort.
In this case OK means saving the TIF with all frames (including the changed one) and Abort means only saving the current frame to the TIF file (which removes all other frames).
There is a checkbox for "Don't ask again", too. But this one makes the Abort-option the default, not the OK-option. So I end up with a TIF-file which only contains the frame which was viewed on saving the file instead of "always save alle frames" how it should be done.
Please fix that checkbox to work as expected ;-)
XnView version: v1.98.5
OS: Windows 7 Professional x64
Re: Bug when saving modified Multi-Frame TIFF
ok, i'll fix it
