Image upload plugins for other image hosting services?
ghost zero
Post by ghost zero »
Does XnView have image upload plugins for other image hosting services [besides ImageShack]? ImageShack is usually very slow and now requires registration to be used--so I'm looking for better alternatives.
ghost zero
Re: Image upload plugins for other image hosting services?
BTW: postimage.org seems clean, simple, and fast. Is there an XnView upload plugin for it?
I must check if there is a simple API
ghost zero
any update on this?
xsoft
Post by xsoft »
Does upload plugin for ImageShack works now? (should I be looed on IS page, or not).
Im unable to do this. (3.2.0 64b)
MartinoAndretti
Post by MartinoAndretti »
Since Imageshack.us requires login Imageshack addon doesn't work here too. Pretty please for update.
ghost zero
imageshack upload addon doesn't work anymore. any fix?
Drahken
Post by Drahken »
One workaround would be to find an image hoster that allows FTP uploads & then just use the FTP plugin. (There are several free image hosting sites with FTP uploading, I did a search for them a while back.)
ghost zero
Drahken wrote:One workaround would be to find an image hoster that allows FTP uploads & then just use the FTP plugin. (There are several free image hosting sites with FTP uploading, I did a search for them a while back.)
can you recommend some good ones?
Drahken
Post by Drahken »
I can't receommend anything specific as I've never actually used any. I looked it up for curiosity reasons. Badongo and imagevenue both look promising, using the search terms "image hosting" and "ftp upload" will bring up more.
Denaud
Post by Denaud »
Anonymous uploading to ImageShack is still possible. It's a shame XnView can't do it (never perfect mind you) but can't someone with the knowledge work out how the Firefox Addon does it?
It's the Addon called Rehost Image: https://addons.mozilla.org/en-US/firefo ... ost-image/
You can use that with any image on the Internet but I also use it locally (like XnView does) from our PC by dragging the image to an open Firefox window (then from the FireFox context menu choose upload to Imageshack). Works perfectly.
And thank you to the people who've worked on XnView. An excellent application! :-)
ghost zero
postimage.org is the best image host, currently. can there be an XnView upload plugin for it?
ghost zero wrote:postimage.org is the best image host, currently. can there be an XnView upload plugin for it?
i'll check
ghost zero
do you know if it's possible yet?
ghost zero wrote:do you know if it's possible yet?
seems that there is no API
