RC6: Dates chopped off in thumbnails and details
marsh
Post by marsh »
Part of the dates are cut off in in thumbnails and details view.
I don't normally use this mode, perhaps I missed a known option about this.
Layout #3. No Folder tree. 800x600, Win2K, Large Fonts.
XnView 1.80 <x>
From what I can see you are using a bit larger system font which might cause the problem. (Perhaps this helps to track the problem, sure enough this is a bug.)
marsh
Post by marsh »
The problem gets worse or better depending on thumbnail size.
This view is using 48x48.
This problem occurs on 1024x768 with large fonts too. I think the bug is directly related to thumbnail size. The smaller the thumbnail, the greater the chance of chopping off information.
Re: RC6: Dates chopped off in thumbnails and details
marsh wrote:Part of the dates are cut off in in thumbnails and details view.
Yes, currently a problem with small thumbnail....
