Auto-rotate "+90° clockwise" without Exif
Peter2
Post by Peter2 »
I have a lot of TIF where I have to rotate the display "+90° clockwise", due to printing problems. I do not need to "rotate and save", only "open - rotate display of every file - print - close".
Any ideas?
Peter
Re: Auto-rotate "+90° clockwise" without Exif
Sorry currently not possible
Dreamer
Post by Dreamer »
If you need to rotate all files in the same direction, what about Batch processing (Ctrl+U) > Transformations > Image > Rotate? You'd need to save the files, but you can delete them later.
Dreamer
Peter2
Post by Peter2 »
Dreamer
thanks for the hint, but I am searching for an option which is offered by other viewers (not image, but other formats). They have an option where you can select "display files always rotated +90 / +180 /+270".
This is fine when
- you have files which are all wrong rotated (for examples wrong produced scans) or
- when you print "same orientation as display" (large formats)
- and you don't want (or don't be able) to rotate
Regards
Peter
