Thumbnailing whole folder removed?
soulky
Post by soulky »
Mp development progress shows:
'create whole folder' disabled, create thumbnails for some next rows - viewtopic.php?f=60&t=24883
Referring to a thread I have started. But why? I never suggested to remove this feature. In fact it is most important as it is simply impossible to thumbnail a folder with 40.000 files by scrolling down manually row by row.
Do NOT remove this feature otherwise MP will be useless for me.
Re: Thumbnailing whole folder removed?
It's not removed, thumbnail processing use some more rows
soulky
Post by soulky »
xnview wrote:It's not removed, thumbnail processing use some more rows
Then what does this mean?
Disabling "ceate whole folder" means that it is no longer possible to create thumbnails for whole folder. So this feture has been removed?
When 'create whole folder' is disabled...
soulky
Post by soulky »
xnview wrote:When 'create whole folder' is disabled...
Ok, that makes sense. "When" is missing in the development progress overview. Maybe you should correct it.
