can i visualize exif date under the thumbs?
drugo
Post by drugo »
Hi
i tried and did search an answer but i did not find it
in the browser , in the thumbs panel , i have the thumbs with the file name , for example photo 24344.jpg
i know there is the tool tip
but can i add some metadata under the thumbs?
for example , data , or exposure bias?
in the preference ->thumbnail label -> there is a list , i tried to add something to the right panel , but i did not solve my problem
so , can i add some info under the thumbs?
thanks
cheers
sorry for my poor english
Re: can i visualize exif date under the thumbs?
Is this what you mean, drugo?
  • Image
drugo
Post by drugo »
XnTriq wrote:Is this what you mean, drugo?
yes but i does add nothing under the thumbs
these are the screenshots
and here you can you see there is nothing under the thumb
as you can see under the thumb there is only the file name img_7777.jpg, nothing else
thanks XnTriq
cheers
Is View » View As set to Thumbnails & Labels?
I used recordshark25008sq.jpg for my tests.
Tools » Options... » Browser » Thumbnails » Thumbnail Label:
  • Creation Date: <Creation Date [d/b/Y H:M:S]>
    Modified Date: <Modified Date [d/b/Y H:M:S]>
    EXIF - Camera » Date modified: <Date [d/b/Y H:M:S]>
    EXIF - Image » Date taken: <Date Taken [d/b/Y H:M:S]>
    EXIF - Image » Date digitized: <Date Digitized [d/b/Y H:M:S]>
[color=green]xnview.ini[/color] wrote:
[Browser]
Custom0=Creation Date: <Creation Date [d/b/Y H:M:S]>
Custom1=Modified Date: <Modified Date [d/b/Y H:M:S]>
Custom2=EXIF - Camera » Date modified: <Date [d/b/Y H:M:S]>
Custom3=EXIF - Image » Date taken: <Date Taken [d/b/Y H:M:S]>
Custom4=EXIF - Image » Date digitized: <Date Digitized [d/b/Y H:M:S]>
drugo
Post by drugo »
XnTriq wrote:Is View » View As set to Thumbnails & Labels?
nope
thanks!
sorry i'm fool
i enabled view as thumbnails & labels now it's perfect!
thanks again
