Windows bmp and Gamma
murahikaru
Post by murahikaru »
First of all I would like to thank you for developing this program, it helped me a lot.
However, I have encountered some problems in the batch processing. I downloaded the
latest version of XnConvert from the official site and the program was accessed through
a NAT network.
1. When the output file type of "BMP-windows bmp" is selected, all the processed (regardless of the
action script) files became 8-bit greyscale bmp. Since my work required bmp files, I was wondering
if there is a way to adjust the output options for bmp files?
2. I cannot get XnConvert to remember the decimal value of Gamma, it would automatically set to
integer regardless of the value in the xbs file or what I have set just 10 seconds ago (e.g. Gamma 1.5 always become 1.0)
If anyone can help with these two questions I will be very grateful.
Re: Windows bmp and Gamma
murahikaru wrote: 1. When the output file type of "BMP-windows bmp" is selected, all the processed (regardless of the
It's a known issue
Ok, i'll fix it
murahikaru
Thank you again for your attension and effort. :D
Please check XnViewMP 0.48
