I have converted in a batch some png icons, and some of them (not all) with transparent background loose the transparency, the bg become black.
XNConvert OSX version.
Regards
Some PNG loose their transparent bg in XNConvert
Re: Some PNG loose their transparent bg in XNConvert
Could you send me a sample?
cktx
I have a PNG image with transparent background which I try to convert to an EMF. In the before and after shows the image with the transparent background. When I perform the conversion the EMF comes with black background. Am I doing something wrong or is it a limitation of the software?
TheLievense
We're having the same exact problem. Transparent PNG gets converted with a black background when converting to EMF format.
yes currently EMF output has no transparencyTheLievense wrote:We're having the same exact problem. Transparent PNG gets converted with a black background when converting to EMF format.
