Date/Time Difference in detailsview and EXIF-Data
LightOker
Post by LightOker »
Hi, I'm using Version 1.98 of XnView and I am very convinced of this freeware.
Now I checked that there is a difference of 1 hour of picture-data between the column 'date in detail-View' and the EXIF data:
The 'detailed view' shows one hour less than the EXIF data. My question is:
What date/time represents the column date in the list:
- exposue time
- change time
- built time ??
Is this a bug or have I have I forgotten to check a certain button in the settings?
Re: Date/Time Difference in detailsview and EXIF-Data
Could you send me a sample?
LightOker
Post by LightOker »
Hallo Pierre,
thanks for your answer. I would like to send you a screenshot of what I mean.
You may have have a look on file DSCF2800.jpg and compare die EXIF data with the column 'Datum' on the right side.
[img][D:\01_HeinzDateien\INFOS\PC\Software\Xnview_Date-Confusion(EXIF).jpg]
I hope this will work...
Lightoker
Sorry there is a problem with the link
LightOker
Post by LightOker »
Sorry Pierre,
i do not know how to add an attachment to this info.
So let's try the following:
Please copy this Internet-link into your browser - this should work...
http://dl.dropbox.com/u/58199045/Xnview ... XIF%29.jpg
Patiently waiting.
Heinz
The date that you see in detail view is the modified date of the file
LightOker
Post by LightOker »
Okay, so i learned that the modification date on the left side is the date of the EXIF-data changed. Most interesting for me is the modification date of the file with respect to the sorting possibilities in the Windows explorer.
Thanks for your help.
Heinz :)
