GhostScript
All non-XnView related: softwares, formats, imaging, photography...
Rostein
GhostScript
Post by Rostein »
Hi, I have a doubt concerning this vector format interpreter and displayer, called Ghostscript
Surfing on the net, I have realized that there are some issues that advise of multiple memory corruption vulnerabilities on Ghostscript software, which could allow remote access to our computers opening any Postscript file. For example, this site explains it:
http://seclists.org/fulldisclosure/2010/May/134
On the other hand, I have online scanned the ghostscript installation file (gs905w32.exe, 12 MB) in order to assure myself it was safe, and some antivirus recognize it like the virus called "PUA.Script.PDF.EmbeddedJS-1". Other sites say that is just a false positive, because some antivirus which use heuristic detection methods doesn't spend time on including some patterns from secure softwares.... but I am not sure....
I tried to scan a early version of ghostscript that I saved many years ago into a CD (2003 or so), and a similar or worse result is given:
AVG --> Suspicion: unknown virus
ByteHero ---> Trojan.Malware.Obscu.Gen.001
F-Prot ---> File is damaged
If these false detections are from an almost 10 years old software... ¿didn't have enough time this antivirus software for including this software as safe? . Or really, isn't it ?
And on top of that, the free application that comes with the ghostscript interpreter, the Ghostscript Viewer, also seems to have a trojan called Trojan.Malware.Obscu.Gen.001, :|
My question is.. Is it safe to install ghostscript?. Are those (false?) detections a serious argument against its installion?. Are those vulnerabilities the proof of those detection are not wrong? And the most important ... ¿ Is there any other free postscript/vector format interpreter and displayer available on the net apart of ghostscript?
Peter2
Re: How to display vector formats like PDF, AI,...? GhostScr
Post by Peter2 »
Ghostscript is a well know software, developed for years and still on current status - is is not "10 years old". It is also integrated in other software packs like PDFCreator and so on.
http://en.wikipedia.org/wiki/Ghostscript
If you download it from the official site it should be secure.
Peter
Rostein
Post by Rostein »
Many thanks for your answer :)
Peter2 wrote: If you download it from the official site it should be secure.
Peter
The fact is that all those detections are obtained scanning the file downloaded from the official site :|
I know that many other softwares (included Windows S.O.) have uncountable known (or unknown) security vulnerabilities, but they are not detected as viruses or trojans like ghostscript ...
Well, :? I refer to the solution given on the site I provided in my first comment and I will search for other PDf interpreters and displayers...
==Solution==
In the absence of a patch, users are encouraged to discontinue use of
Ghostscript or avoid processing untrusted PostScript files.
Peter2
Post by Peter2 »
Rostein wrote:
==Solution==
There is a difference between an "unsecure software" and "untrusted PostScript Files". Are we talking about the same thing?
Peter
Rostein
Post by Rostein »
Peter2 wrote:
Rostein wrote:
==Solution==
Peter
You are right, but maybe the virus traces detected by some antivirus may be caused by those vulnerabilities, right?
That issue says ghostscript may be the door to harmful remote entries (but not that the software is a virus itself)... but at the same time, the virus scanning reports that the installation file is a malware itself.. I dont know what to think.
Peter2
Post by Peter2 »
Rostein wrote:.. I dont know what to think.
I don't know either...
I never heard that PS-files open a door for malware, but maybe you will find something in the internet?
And if the PS is the problem, maybe other PDF-software has the same problem?
No idea ...
Peter
