option to just select fileswith a rating > 3*
fpdave100
Post by fpdave100 »
Is this possible.
I'd like to automate syncing to a device / shared drive but only sync pics that I've rated above a certain value, and xnconvert can almost do everything I want (watermark, reduce, jpg quality, etc), but thereare few things it cant:
- filter by just files witha certain rating or above
- output into the same folder structure as it read the file from (or can it now do this?)
Lovely tool otherwise - much better than the one I started writing before I found this!!
venusgrogan
Re: option to just select fileswith a rating > 3*
Post by venusgrogan »
I hope it is.
