Is multipage TIFF creation actually working?
guakamole
Is it actually possible to create multipage TIFF files in the program? I go to Tools>Multipage File>Create, add a number of files and then select 'TIFF revision 6' but it is only the first file in my list that appears in the newly created TIFF file, no sign of multiple pages at all. Am I missing something? Multiple-page PDFs are created without problem though.
marsh
Re: Is multipage TIFF creation actually working?
It works perfectly for me in v1.98.7 so far. With several jpegs as source.
guakamole
Yeah, I got it... ToolBar should be on, with its arrows for scrolling through 'pages', otherwise you may just fail to realize that you are having a multipage file in front of you... not very convenient I'd say...
marsh
There are many 'do not show again' dialogs which will need to be reset by hand (renaming ini, recreating new settings). Including one about multipage. A better sort of indicator would be useful here, IMO.
