Hello
It seems, when batch processing, add file, the include subfolders check box does not appear to do anything, or at least not add subfolders.
Query came up in my post "Batch Convert Single File Type", under general support.
Thanks
Roper
Batch Processing Add Subfolders
Re: Batch Processing Add Subfolders
Used when you drag&drop folder in the list below
