Blank pages when printing PDF
aklan14
Post by aklan14 »
I wanted to print in pdf (with pdf creator or Adobe PDF) a large number (around 100) of PDF files in order to add for each of them the filename on the top of the document. First documents have been correctly printed but after 40 documents, for most of them, xnview generate blank pages.
Were you already faced this kind of problem?
Thanks
Alban
aklan14
Re: Blank pages when printing PDF
Post by aklan14 »
OS : Tested on Windows 7 and Windows 7 Home premium
xnview version: 1.98.8
Peter2
Post by Peter2 »
aklan14 wrote:...I wanted to print in pdf (with pdf creator or Adobe PDF) a large number (around 100) of PDF files ...
You want to print 100 PDF to one PDF with an image viewer?
Maybe some PDF-tools can help you: http://www.noliturbare.com -> see PDF-tools and Links
Peter
aklan14
Post by aklan14 »
Thanks Peter for your answer,
However, I didn't find exactly what I need. I want a tool which add the filename on the top of each my PDF . Xnview can do this but I could't find such feature in tools present on the site you suggested.
Alban
Sorry but you can't edit the PDF without PDF=>bitmap=>add text=>PDF
aklan14
Post by aklan14 »
xnview wrote:Sorry but you can't edit the PDF without PDF=>bitmap=>add text=>PDF
I don't understand. When I print an existing PDF file, in printing options I can define that xnview add the filename (or file size, last access...) on the header of each my document.
This feature is very useful for me, but when i print several documents, some of them are blank (but not all).
The most surprising thing is that more I try to print a group of pdf file, more the number of blank pages increase.
I tried to find other software easy-to-use to do this, but unfortunately I couldn't.
Thanks
Alban
Oh sorry when you print...
Could you send me a file with always the problem?
