IconLover
A powerful, easy-to-use utility for finding, extracting, creating and editing icons and cursors and managing icon libraries and image lists.
With IconLover, you can:
- Manage icons, static and animated cursors, icon and cursor libraries and image lists
- Create and edit smooth semi-transparent icons, static and animated cursors for Windows XP
- Create and edit icons in standard and custom sizes, with color depth up to 32-bit True Color
- Make stylish icons from your images
- Paint images with gradients and fills
- Create multi-layer images
- Modify images with drop shadow, opacity, smoothing, negative, grayscale, colorization, rotation, roll and mirror effects
- Import and export ICO, BMP, JPEG, ANI, CUR, GIF, PNG, TGA, TIFF, WMF, WBMP, XPM, XBM and Adobe Photoshop PSD image formats
- Import Mac OS icons from ICNS and RSRC files
- Manage icon libraries for better and more efficient image storage
- Extract icons from Windows executables, libraries and animated cursor files, ZIP and RAR archives
- Download icons from the Internet
- Modify icons inside executables
- Search in folders for icons and cursors
- Convert or apply effects to multiple icons at once
- Customize desktop and folder icons
Home page:
____www.aha-soft.com
IconLover
budz45
