Render image BEFORE showing
freakingprime
Post by freakingprime »
Hi.
When I switching to a large image, XnView first show it blurred, then sharpened. This happens fast, but still annoying.
I suggest to complete render the image then show it later, that brings better feeling when using the program.
Sorry for bad English.
Sincerely.
Re: Render image BEFORE showing
you can change the settings in option/Fullscreen>Use delayed high quality...
freakingprime
I'm using XnViewMP, and there are no such option.
Plus, I never use full screen mode, just view mode. Is there any other way to fix the problem?
marsh
Post by marsh »
freakingprime wrote:I'm using XnViewMP, and there are no such option.
Maybe turning cache on will change display.
- v.39(L) HQ is 2 pass with cache disabled
