change Name and set GPS
mfeske
Post by mfeske »
at first sorry for my bad English. I will try to say what is the problem but my Mother Language is German :-)
It is Possible to Change the name with a Script? I have a Script to hange the Size an set a Text, but I haven´t found to change the Name
It is possible to set the GPS Koordinaten if theire is no Tracking for?
Greetings
Micha
Re: change Name and set GPS
the filename?
mfeske
Post by mfeske »
yes the filename, and the gps koordinates
in batch convert? You can not change GPS values...
mfeske
Post by mfeske »
Okay thanks, the batch for rename I found, but I hope I can do this by resize and writing on Picutre Script. GPS Koordinates was by nconvert possible?
mfeske wrote:Okay thanks, the batch for rename I found, but I hope I can do this by resize and writing on Picutre Script. GPS Koordinates was by nconvert possible?
You can use btach convert to resize. No you can't modify GPS with nconvert
