pct files
Cobra
pct files
Post by Cobra »
Hi there,
I have to say XnView is awesome. I couldn't even count the hours this little beauty will save me in the long run.
An odd occurrence I found is when I batch resized the canvas of some pct files the output files were pngs even though I told it to output the same as the source file type.
I've attached one of the offending pct files in the event this could help diagnose the cause of this.
Thank you for any help in advance.
Re: pct files
Could you post the result png?
Cobra
Re: pct files
Post by Cobra »
Sure, here it is.
Re: pct files
Sorry but what's the problem? With XnViewMP?
Cobra
Re: pct files
Post by Cobra »
I told XnViewMP to output the same file type but instead it outputted the png.
Re: pct files
MAc PICT format is not possible with XnView
Cobra
Re: pct files
Post by Cobra »
That explains it then. Will it be supported some day?
At any rate thank you for your time.
