Progress bar during Copy/Move
vovka
Post by vovka »
Hi, Pierre.
It would be nice to see a progress bar during Copy/Move operations in browser.
Sometimes it takes much time to copy a hundred or more files and XnView shows no activity at that time. One cannot tell whether it's working or hanging.
Re: Progress bar during Copy/Move
You have not the standard dialog with animation like windows explorer??
vovka
Post by vovka »
xnview wrote:You have not the standard dialog with animation like windows explorer??
No, I see nothing, Xnview just stops responding until operation is finished.
How do you make the copy/move? Drag&drop?
vovka
Post by vovka »
I use Copy to folder... (Alt+C) and Move to folder... (Alt+M)
