Greetings,
I'm trying to use XnView to view and convert several files created by Word Perfect Graphics. XnView doesn't recognize these files, yet it is advertised to do so. What do I need to make this happen?
I'm using Win XP and have plenty of memory and storage.
Thanks
Word Perfect Graphics files
Drahken
Re: Word Perfect Graphics files
Have you tried making sure the all formats option is on? tools->options->general->"display all image file types"
pdeanb
Yes. The little box has the check mark. I made sure of this because after clicking on a file with the .wpg extension, a note came up which told me to try that.
What else should I try?
pdeanb
Drahken,
I just installed Xnview on another computer and trying to open a .wpg file does exactly the same as on my first computer. I was concerned that my first computer was possibly messing up somehow.
XnView can only load embedded thumbnail for some wpg files
