JXR Color format and block filtering
starburst
I was wondering how you set the Color Format and Block Filtering when you convert to JXR if possible with NConvert like in XNView, Thanks! Really great program, loving it!
Re: JXR Color format and block filtering
Ok, i'll add it
starburst
Merci Pierre!
boostworthy
Yes, I am very interested in this as well.
boostworthy
Pierre - just wanted to follow up on this request. Is there a new build available with this implemented or is it still under development? Thanks again; I really appreciate it!
