Convert to RAW using Nconvert6.05
ghgnam
Post by ghgnam »
I'm unable to convert TIFF-format files to RAW-format files using
Nconvert V6.05 (Windows 7 64bit). Using the Version 4.25 it is possible.
Is it a bug or is it no more supported ?
See the Output below.
Thanks Reinhard
REM &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
set RSB=D:\rs\binpano\nconvert6.05.exe
set RSB=D:\rs\binpano\nconvert.exe
%RSB% -npcd 2 -size 1768x8140+0 -ctype rgba -corder inter -out raw -gamma 1.33 -o "C:\X\TEMP\q.raw" "C:\X\temp\NNEBP008A.tif"
REM -----------------------------------------------
REM set RSB=D:\rs\binpano\nconvert6.05.exe
rem ** NCONVERT v6.05 (c) 1991-2011 Pierre-E Gougelet (Feb 23 2012/21:40:50) **
rem Version for Windows Xp/Vista/7 x64 (All rights reserved)
rem ** This is a freeware software (for non commercial use)
rem Error: This output isn't possible (not yet implemented) (C:\X\TEMP\q_1.raw)
rem -----------------------------------------------
REM set RSB=D:\rs\binpano\nconvert.exe
rem ** NCONVERT v4.25 (c) 1991-2004 Pierre-E Gougelet (Oct 8 2004/15:42:00) **
rem Version for Windows NT/9x/2000 (All rights reserved)
rem Conversion of C:\X\temp\NNEBP008A.tif into C:\X\TEMP\q.raw OK
Re: Convert to RAW using Nconvert6.05
Perhaps a bug, i'll check
